v6.74+dev0203 - February 3 2023
* Includes feature branch: improved mousewheel and gesture accuracy
* Includes feature branch: text/control alignment improvements
+ Accessibility: improve tab ordering of various child windows
+ Actions: meta actions to modify MIDI CC events can generate more precision
+ Actions: remove actions like "set default mouse modifier for context to action"
+ Fades: add preference to not create fades larger than X pixels when splitting
+ IDEs: improve indentation behavior when copying multiple lines including a partial first line [t=275533]
+ IDEs: improve indentation behavior when pasting multiple lines
+ MIDI: when trimming items on split, remove duplicate CCs, chase PC [p=2642901]
+ Media item lanes: add action to explode takes to fixed lanes
+ Media item lanes: add action to explode takes to fixed lanes and create comp areas from active takes
+ Media item lanes: add action to toggle preference for auto-fade/auto-crossfade when comping in fixed lanes
+ Media item lanes: add actions to set item colors per lane to lane button context menu
+ Media item lanes: automatically convert track to fixed lanes when initiating comping
+ Media item lanes: automatically explode takes to lanes when setting track to fixed lanes
+ Media item lanes: automatically heal splits when exploding takes to fixed lanes
+ Media item lanes: explode takes to fixed lanes when initiating comping on non-fixed-lane track
+ Mouse modifiers: add 3 arrange view mouse modifier override sections
+ Mouse modifiers: add actions to activate/toggle/clear mouse modifier overrides
+ Mouse modifiers: add actions to set override arrange view mouse modifiers until next mouseup
+ Mouse modifiers: add toolbar buttons to enable override mouse modifiers
+ Mouse modifiers: set override section C to fixed lane comp area behaviors by default
+ Mouse: improve accuracy of mouse gestures and mousewheel when bound to actions
+ Preferences: reorganize Appearance tab slightly
+ Theme: add animation_toolbar_armed and animation_toolbar_highlight png stacks
+ Toolbars: add preference/appearance/toggle action ID highlight configuration
+ Toolbars: allow slightly more text on buttons
+ Toolbars: animate/blink a configurable list of enabled toggle actions (e.g. ripple editing)
+ Toolbars: animate/blink armed actions
+ Windows: fix return key on various buttons including Preferences
# ARA: fix action to return unpooled takes to ARA pool [p=2641895]
# Main alternate sections: actions to set override are now toggles
# Media item lanes: change behavior of mouse modifiers to move comp area without affecting other comp areas, to move comp area without attaching to other comp areas
# Media item lanes: fix comp areas going out of sync when changing comping lanes [p=2641414]
# Media item lanes: fix inconsistent edge-attach behavior between left and right edge
# Media item lanes: fix targeting mute/solo buttons with certain TCP space configurations [p=2641543]
# Media item lanes: hide lane-add area when it is less than 2/3 the height of a lane
# Media item lanes: mouse modifiers to move comp area and split and move media items does not attach to other comp areas
# Media item lanes: prevent creating comp area when dragging in comping lane unless mouse is within an existing comp area
# Media item lanes: properly apply changes to default comp area crossfade length
# Media item lanes: syncing improvements
# Media item lanes: update TCP display after inserting or deleting fixed lane
# Media item lanes: update comping lane when source item color changes
# Media item lanes: when initiating comping with no comping lane set, activate top lane if it is empty
# Media items: fix restoring item grouping when loading project [p=2641397]
