v6.77+dev0307 - March 7 2023
* Includes feature branch: display render peaks for selected file
+ FX: always run FX when muted if the UI is visible
+ FX: always run FX while stopped if the UI is visible [t=273647]
+ Render: $marker wildcard matches the first marker within the rendered time range, or latest marker before the start [t=276600]
+ VST: change 12/14/16 channel mode priority to default to 6.75 behavior [t=276901]
+ WALTER: add tcp.fxlist and master.tcp.fxlist, images [master.]tcp_fxlist_[norm/byp/off/empty/bg]
+ WALTER: add tcp.fxparm.onlyparm/master.tcp.fxparm.onlyparm, which if set to [1] will make tcp.fxparm always exclude sends/inserts
+ WALTER: add tcp_fx_enabled to go with existing tcp_sends_enabled, indicates status of 'Show FX in TCP' option
# Media item lanes: allow editable comp areas to un-sync when editing media items in comp lane
# Media item lanes: allow razor edits in comp lane to un-sync comp areas
# Media item lanes: creating comp area from razor edit affects all razor edits, not just the clicked one [p=2656525]
# Media item lanes: do not use empty first lane as comp lane [p=2656522]
# Media item lanes: don't crossfade MIDI items when comping
# Media item lanes: fix delay when editing media with customized playback rate [p=2656341]
# Media item lanes: fix item playrate changing when splitting at comp area edges [p=2656083]
# Media item lanes: fix overlap when splitting media items at comp area edges
# Media item lanes: support copying comp areas using razor edits
