v7.09rc1 - January 14 2024
* Includes feature branch: improved FX preset navigation with user/default presets of same name
+ Default 6.0 theme: add retina meter mute/unsolo/dim images [t=286642]
+ Envelopes: revert bad fix for looping automation item sine/parameteric LFO types [t=285838]
+ FX: improve preset navigation behavior when both user and default presets exist with the same name [t=270990]
+ Glue: fix crash when gluing empty items (7.08 regression) [t=287133]
+ Input FX: fix potential crash with record arm disabled and input FX UI open (7.0 regression)
+ JSFX: report correct samplerate in @init when ext_noinit is used [t=286975]
+ Jump to time: if primary ruler display is samples, parse user-entered 8-digit number as samples rather than timecode [t=287041]
+ MIDI: remove MIDI media items on hidden tracks when selecting other MIDI items [t=286973]
+ Razor edits: fix undo after applying razor edit to envelope [t=287175]
+ Recording: support $recnumber and $recnumber[N] wildcards, resolves to 1 for the first recorded file with the same name, 2 for the second, etc
+ Track manager: allow searching for tracks by name in collapsed folders [t=279605]
+ Video: fix reverse and section playback (7.08 regression) [t=287183]
