v7.09+dev0202 - February 2 2024
* Includes feature branch: Media Explorer time selection, channel selection improvements
* Includes feature branch: VST prefetch reporting
* Includes feature branch: envelope list window improvements
+ API: support get_config_var(__fx_loadstate_ctx) for VST/CLAP use, char value will be 'P' if loading preset/via script, 'u' if instantiating from undo, 'U' if loading updated undo state
+ CLAP: add per-plugin option to disable offsetting automation by PDC amount [t=287191]
+ Media explorer: disable reverse preview for MIDI (playback has never been supported, but display was misleading)
+ Pan law: set default for new projects to hybrid taper [p=2753690]
+ Preferences: remove misleading 'ms' label on default media item fade-in/fade-out
+ Razor edit: fix deleting tiny media items [t=287852]
+ Regions: add actions to set loop points to current, previous, or next region
