v7.11+dev0223 - February 23 2024
* Includes feature branch: color media items peaks by calculated loudness or display loudness graph on items
* Includes feature branch: Media Explorer time selection, channel selection improvements
+ Default theme: make auto-hiding of envelopes/routing buttons behave similar to Default 6 theme
+ macOS: improve peaks drawing quality in Retina mode
# Mouse modifiers: fix cursor when over track spacer and mouse modifier override is enabled
# Mouse modifiers: revert 'respect arrange view mouse modifier overrides when the mouse is over razor edits or comp areas'
# Peaks: add color band, change default levels/colors
# Peaks: add even more loudness peaks color bands (previously saved presets will be discarded)
# Peaks: enable entering numbers directly in peaks display settings edit boxes
# Peaks: fix adjusting loudness peaks/graph by fades, item gain, take envelopes
# Peaks: improve loudness graph drawing
# Razor edit: improve preview display when edit begins or ends over a track spacer
