v7.11+dev0226 - February 26 2024
* Includes feature branch: color media items peaks by calculated loudness or display loudness graph on items
* Includes feature branch: Media Explorer time selection, channel selection improvements
+ Lanes: update display after auto-punch recording with comping enabled [t=288667]
+ Peaks: add load/save/rename preset, reset to default to '...' dropdown menu in peak display settings window
+ Peaks: add option to display tooltip with peak value and loudness (if peaks configured to calculate loudness)
+ Peaks: support renaming presets for spectral, loudness, spectrogram peaks
# Peaks: add menu item to open peaks generation and caching settings from peaks display settings window
