v7.11+dev0305 - March 5 2024
* Includes feature branch: color media items peaks by calculated loudness or display loudness graph on items
* Includes feature branch: Media Explorer time selection, channel selection improvements
+ Accessibility: improve application-key menu behavior in various listviews
+ Accessibility: improve preferences/item fade defaults accessibility descriptions
+ Actions: add actions to mark take under mouse as favorite or for deletion
+ Color theme: add separate take marker color for selected items
+ Freeze: exit comping when freezing a track
+ Freeze: treat media items on fixed lanes that do not play as if they were muted items
+ Lanes: add actions to explicitly set (rather than toggle) recording options to add lanes, add lanes in layers, or not add lanes
+ Lanes: change description of existing 'new recording adds lanes' action to make clear the action is a toggle
+ Lanes: sync source lane take markers to comping lane
+ Localization: add option to ignore langpack-defined scaling
+ Localization: add option to show unlocalized strings in menu items
+ Localization: option to show tooltips with pre-translated text on mouseover
+ Metadata: remember last metadata scheme selection when reopening REAPER
+ Render: fix peaks display when calculating loudness of selected items via dry run render [t=288907]
+ Take markers: actions to mark last take as favorite or mark for deletion act as toggles (markers are deleted if they already exist)
+ Take markers: avoid possible crash when editing or deleting take markers on currently-recording items
+ Take markers: reverse sync edits to take markers from comping lane back to source lane [t=288992]
+ Takes: rename actions like 'mark take for deletion' to 'mark take as non-favorite'
# Peaks: fix incomplete peaks drawing in envelope lanes when media items are not visible on screen [p=2763456]
