v7.13+dev0402 - April 2 2024
* Includes feature branch: happy/sad markers
+ MIDI editor: when using mouse modifier to move note on one axis only, lock movement to one axis once the move has been initiated
+ Media items: don't show locked item button when items are too small
+ Preferences: add maximum stretch marker handle size configuration
+ ReaDelay: improve length parameter names
+ Take markers: support copying take markers via ctrl/cmd-drag
+ Take markers: support editing take marker position in take marker dialog
+ Take markers: support length parameter for take markers
+ Takes: remove per-take up-rank/down-rank button (use menu or actions to insert up-ranked/down-ranked take markers instead)
+ VST: fix bugs in mainthread-only automation notification response mode
+ VST: ignore feedback parameter change notifications from plugins while automating
# Accessibility: improve labels
# Media items: hide take FX button when items are small
# Take markers: fix actions adding take markers to unselected media items
