v7.15 - April 17 2024
+ Accessibility: improve descriptions for various FX/JSFX text edit fields
+ Accessibility: improve keyboard accessibility of various sliders via pageup/down, home/end
+ Accessibility: improve macOS VoiceOver keyboard focus behavior for sliders in FX, other windows
+ Actions: clarify that split actions that select the left-hand item also crossfade to the left of the split point [t=286185]
+ Actions: respect global crossfade preference when running actions to split items on grid or at markers
+ API: extend screenset API slightly for ReaImGui
+ Color theme: fix labeling of odd vs even media item background color in theme tweaker [t=289479]
+ FLAC: display error message when attempting to record or render to an unsupported FLAC configuration (more than 8 channels, etc)
+ FX: allow reordering reaper-native presets using ctrl+up/down with preset combo box focused
+ FX: improve pin connector dialog default size with JSFX [t=290028]
+ FX: parse -inf user input in various ReaPlugs dB contexts
+ FX: improve ReaDelay length parameter names
+ Lanes: fix comp areas breaking when using multiple comping lanes [t=290278]
+ macOS: fix mousewheel support in menus on Sonoma
+ macOS: improve FX plug-in resize behavior when switching monitors on recent macOS versions
+ Media Explorer: improve preserving non-overwritten .mp3 metadata when adding new metadata
+ Media explorer: support displaying embedded image metadata (via action or double-click on 'image' column)
+ Metadata: automatically set/clear default image type when setting/clearing image metadata
+ MIDI editor: improve appearance of measure start with swing grid enabled [t=283527]
+ MIDI editor: improve behavior of actions to move notes left/right by grid when using swing or non-1.0 playrate
+ MIDI editor: improve keyboard navigation when using swing grid [t=288971]
+ MIDI editor: improve swing grid behavior with non-1.0 playrate
+ MIDI editor: improve various grid/editing behaviors with 'ignore project tempo' enabled
+ Mixer: allow moving tracks to before, within, or after an existing spacer that is before or after the track [t=288785]
+ ReaScript: do not correct reversed FX min/max parameters in SetParamNormalized [t=290126]
+ ReaScript: fix GetThingFromPoint() when mouse is over track manager and track manager is displaying no tracks [t=290056]
+ Regions: fix moving/copying regions with locked media items [t=290117]
+ Render: support preserving existing metadata (using best efforts) when rendering master mix or tracks, not just selected media items
+ Splash screen: increase status granularity when scanning MIDI devices
+ Take markers: do not display markers that occur before the visible item start, regardless of zoom level
+ Theme: fix volume knob size in strip mixer
+ Tooltips: clear media item tooltip correctly [p=2773110]
+ VST: fix issues when recording automation on highly-automated plug-ins
+ VST: fix support for mapping high MIDI buses to VST3 MIDI buses [t=284552]
+ VST: ignore feedback parameter change notifications from plugins while automating
