v7.15+dev0417 - April 17 2024
* Includes feature branch: support position/length in samples in Item Properties
* Includes feature branch: advanced preferences option to limit display rate
* Include feature branch: improved time signature marker editing behavior
* Includes feature branch: support adding image metadata to mp3 files in Media Explorer
* Includes feature branch: optionally prompt to adjust tempo of empty project when importing media
* Includes feature branch: up-rank/down-rank takes and take markers
+ Audio Units: fix display of stepped parameter when minimum value is not zero [t=290386]
+ Media explorer: improve resizing behavior on linux
+ ReaComp: improve behavior on threshold automation [p=2775220]
+ ReaScript: GetUserFileNameForRead supports trailing slash in filename in order to set initial path only
+ ReaXComp: improve behavior on threshold automation [p=2775220]
+ ReaXcomp: remove denormal noise from filters [p=2775795]
+ Render: support $marker[001], $region[001], etc to apply offset or number [t=290337] of digits to marker or region number
+ Undo: fix automatic record-arm inconsistency after undo [t=290347]
+ VST3: possible fix for possibly incorrect .vstpreset export [t=290322]
