v7.15+dev0422 - April 22 2024
* Includes feature branch: actions to split with crossfade left, center, or right of split point
* Includes feature branch: changes to lane recording settings and behavior
* Includes feature branch: preferences resizing
* Includes feature branch: support position/length in samples in Item Properties
* Include feature branch: improved time signature marker editing behavior
* Includes feature branch: support adding image metadata to mp3 files in Media Explorer
* Includes feature branch: optionally prompt to adjust tempo of empty project when importing media
* Includes feature branch: up-rank/down-rank takes and take markers
+ AU: provide track name context info for plugins that request it
+ Actions: all actions to split at time selection (crossfading to inside, outside, or center) will split on razor edits instead, if any exist
+ Automation: add option in preferences/buffering to control whether anticipative FX is used on tracks in automation write modes
+ Razor edits: default actions/behaviors that split at razor edit edges crossfade to the inside by default, rather than to the right
+ ReaControlMIDI: fix ReaScript and automation issues with Bank LSB parameter [t=289639]
+ Record arm buttons: improve behavior of ctrl+alt click (exclusive-sets track and any grouped tracks)
+ Render: add option to preserve source start offset when rendering media items
+ Render: if option enabled to preserve metadata, preserve existing BWF metadata and ignore BWF-related .wav configuration settings [p=2777573]
# Actions: remove action to split at razor edit edges
# Localization tooltips: fix potential crash when no common section is present [p=2777400]
