卧室制作人博客:Synth Bus Lite By Final Mix Software Is Free Until October 31st
Final Mix Software offers the Synth Bus Lite ($19 retail price) plugin as a free download until October 31st, 2021. Apply the coupon code OCTOBER2021 while checking out to get this offer.
SynthBus Lite is a bus signal processing plugin for keyboards and synths. It’s convenient and works intuitively for all your music projects.
It has an easy-to-use interface that won’t overwhelm you with a thousand dials and complex graphs. Despite its simplicity, it works flawlessly on practically any synth or keyboard sound you could imagine.
Synths are often hard to balance in a mix, but SynthBus makes it easy. Instead of trying to find the correct settings for each synth in your mix, SynthBus Lite has five different instrument-specific presets:
  • Piano
  • Rhodes
  • Wurlitzer
  • Synthesizer
  • Organ
Each preset feels modern, exciting, and suits the instruments.
You can use this plugin on just about any genre of music you like, from retro and hip-hop to even rock and metal. Whether you want your synths to be crisp and punchy, or smooth and mellow, this covers it all.
Each instrument’s tone can be further modified using the ‘Color’ dial, which has five settings – None, Single, Double, Triple, and Max. This lets you control the intensity of the processing.
There is an Input Drive setting on the left of the two dials, which allows you to adjust the gain of the signal before the processing. This gives more headroom for changes to your synth tone before the final mixing, making your job simpler.
The volume indicator is at the bottom of the interface, color-coded to indicate when the sound is clipping. You can adjust the Input Drive until it sits in the sweet spot.
Also, Final Mix Software is not new to the plugin scene. It was started in 2014 by Rob Chiarelli, whose production work has won him multiple Grammy Awards. He’s worked with renowned artists like Will Smith, Christina Aguilera, Stevie Wonder, Pink, and many more.
So far, they’ve released over half a dozen signature plugins that Rob himself uses. You can also check out their MixBus, DrumBus, and BassBus Lite plugins for more signal processing.
And not only are all their plugins extremely affordable (at $19 each), but they also do regular giveaways! They recently offered the M1LimiterLite plugin for free. So stay tuned for more free coupon codes!
If you’re tired of spending hours making your synths sit in the mix, get SynthBus Lite for FREE while you can!
Synth Bus Lite (FREE with coupon code OCTOBER2021)
资讯出处:Synth Bus Lite By Final Mix Software Is Free Until October 31st - Bedroom Producers Blog
